Yeah i got that bit from your other posts as well. I do appreciate the awesome recommendation for that particular chain for the sr1a, but i dont think my wallet can go up that high. The thing is im usually really into detail monsters for my amps and dacs and always chase the maximum amount of speed and clarity. Although, now you've got me doubting my plans and i suspect itll be too harsh as well. For my budget, i think i might swap for schiit Tyr and/or singxer sda-6 for some added warmth.Sorry to hear about the bad luck with the 005.
The DAC3B is not as good as the 005. It is a bit fatiguing on top. I definitely do not recommend it with the SR1a with anythng other than the VM-1a. The AHB2 is also another amp that I do not recommend with the SR1a. When I used it with the SR1a I had 2 smooth pieces in front, the Musetec 005 DAC and the CODA 07x preamp, which were excellent with the SR1a. However, the AHB2 with a DAC3B and/or the Benchmark LA4 preamp is awful with the SR1a. The AHB2 with the Schitt Freya+ was rather good with the SR1a. The bloom in the Schitt tube preamp works well with the SR1a, though it is not as detailed as some other combos. The AHB2 is very tricky to get right with the SR1a, however, with my KEF LS50 speakers, the AHB2 is the best amp I have tried.
Now all this gear I am mentioning is much easier to pair with on my speakers. The SR1a was more difficult to get right.
When I get the VM-1a in the house, I plan on using the Benchmark DAC3B with it, instead of the Mustec 005. This is just a guess but that pairing maybe preferable to my ears. I have heard the DAC3 + VM-1a before and it was amazing.
Recently, with my CODA #8 being sold, I was able to reconfigure some gear in combos that I always wanted to do.
1) My CODA 07x preamp with my ABH2 and KEF LS50 speakers (one day upgrade the speakers).
2) The other system was my Benchmark LA4 preamp with my KRELL 175XD amp. The Musetec 005 DAC is on this system
The LA4 and KRELL combo is quieter than the 07x preamp and has a bit more bite to the music, which the KRELL can handle. The reason I say this on the RAAL SR1a thread, is that on my SR1a, this combo is hands down the very best combo I have heard on the SR1a using 2-channel gear. In the past I said the following was the best:
CODA 07x preamp | Musetec 005 DAC | KRELL 175XD
I like the following more:
Benchmark LA4 preamp | Musetec 005 DAC | KRELL 175XD.
This combo comes awfully close to the VM-1a. At least my audio memory from last month when I heard the VM-1a. It costs a lot more than the VM-1a and is not at the same level, but it is a great backup for me when the VM-1a needs tube replacement. It is also my 2-channel speaker gear. I unplug the speaker wire and puit it into the RAAL interface box when I use the SR1a.
They told me my 005 problems are quite unique, so for now ill just assume its a one off and just simply bad luck - REALLY bad luck, as it costs me 350$ to ship it back to shenzenaudio.
