My comments are also on that linked thread (user yyz). Yesterday I sold my dedicated RAAL SR1a DAC because with the Convolution filters it was no longer needed. I am now using what was the worst possible DAC, the Benchmark DAC3B that I tested with the SR1a. With the filters, it is almost as good as the very best DAC I have, the Gustard X26 Pro. I need the Gustard in another room so I am using the DAC3B now. I can live with this. Without the Convolution filter I was not able too.
Appreciate the input. That's a pretty bold endorsement...
I'm going to take the plunge on the filters (I just emailed Mitch). However, I run a custom audiolinux Roon + HQPlayer from Pareto audio and I wondering what the best path for implementation would be. It would be great to be able to integrate Mitch's filters with HQP in combination with upsampling to 768k, or in stand alone with Roon. Any recommendations?
Edit: after speaking with Mitch, the answer is both. The filters work for both Roon and HQP. For HQP, you would take the highest sample rate filter (i.e. 352.4 kHz) and load that into HQP and then upsample. The regular stereo filters are used natively in Roon. That way you can experiment between the two.
