TL;DR: Really enjoying the Raal, incredible wow factor and extremely impressive. I've had the 009 at the top of my list all time, and this is the first headphone I've tried that does some of the things it does best, considerably better & with cohesion. The TC has come close in that regard by matching or even besting the 009 in some technical areas, but the lack of cohesion/presence in the midrange has the 009 clearly ahead for me. The Susvara comes close to the 009 in almost all areas but doesn't match or surpass it (besides bass). For me, that's a really huge realization/experience to have, quite a big deal. The bass *is* lighter than most of the other TOTL cans, but is of high quality and once acclimated to the sound, sounds really good and fits in the spectrum really well. Also, will be looking to replace the Jot R immediately, just a really disappointing (distortion) experience overall with it. (FYI, to avoid the Jot R issues and impact, I have been either listening to songs at moderate volume or leaning towards music with less bass impact and punch to listen louder and more critically)
Whenever I get a substantial new piece of gear, I hold off on major impressions or detailed opinions.. just because they typically develop and mature over time. Will generally do the same here, but I have to say.. I have a really good handle on the SR1a already. Mainly due to them being nearly exactly what I imagined in almost every regard. Having owned the AKG K1000 four times, I expected the Raal to function and sound like a more improved K1000--that is very much the case and it improves on some of the major issues the K1000 had. That said, it still has some imperfections/issues similar to the K1000. Just a couple quick, broad thoughts.. but keep in mind I absolutely expect the sound to improve with a better/sufficient amp) :
1. The Sr1a is top three imo when it comes to realism and wow factor, along with the TC and 009. It's just insane when it comes to the presentation of the music, extremely surreal.. once acclimated to the sound. I can easily identify the differences that stick out for each and can't wait to give it time to come with detailed elaboration on this.
2. Most speaker like headphone experience.. prior to this, I had the L3000 (intimate midrange/bass) and TC (technical ability/openness/bass) as kings in that regard.
3. As hinted at, you definitely need 20-30min to really adjust to the presentation.
4. Just like the K1000, all of the positioning can be a bit daunting to sort out, but there is one key positive difference. To my ears, the K1000 had a sweet spot.. they didn't sound great all the way closed in or all the way open. The Raal sounds really good in all positions.. but that makes it even more annoying lol because it means I'll be tinkering with it more based on the song/genre/mood at the time.
5. Incredibly good with acoustic music. Probably better than the 009 and I have never heard a headphone that does it better than the 009. That's a pretty big deal to me.
6. The bass although really high quality and very tight, definitely is on the lighter side and is just not great with music that has larger quantities of, or, moderately deep/really deep extending bass. This is partly due to the design and both headphones have an issue with it. Again, after more time I'll come back and elaborate. I also have an issue with the Jot R that contributes to this problem, but it isn't just that. Lastly, I can easily say that despite this, it's performance with acoustic, vocal (emphasis) heavy music is totally worth it and that in many cases the bass is sufficient enough.
7. It's not the fault of the Raal, poor recordings for the most part are unlistenable. This is not the case with any other headphone I have. It's a bit of a bummer. Some of my favorite reference tracks, even steamed via Tidal MQ are just unlistenable.
On to the Jot R.... I have to say I am incredibly disappointed in this amp. For starters, it cut off due to heat literally 40min into the very first session.. that has been a major issue ever since. This is in a cool, well ventilated room/setup (this amp wouldn't stand a chance in summer months). Whether using the WA33 as a preamp or not. Balanced or SE Dave. Onto the second and most glaring issue... distortion. The consistent distortion with this amp and the Raal is simply unacceptable. I do want to be clear, it's not an insane level or amount of distortion.. it's low level but is apparent with any song that isn't essentially void of deep bass impact--have to virtually avoid half of my music collection. Again, with the WA33 or not, or SE or Balanced Dave. It doesn't matter, just pretty bad in general. Some distortion, on some tracks, at higher volume.. with this headphone design is to be expected. I am very familiar as the K1000 has the same exact design challenges (just google K1000 distortion or buzzing). However, there is far more consistent distortion than I've ever experienced with the K1000. Couple things on this:
1. With the baffle switch set to off, it is much less of an issue.. but the SQ decreases very noticeably.
2. Baffle switch set to on, it's not an issue at all with music with minimal bass impact/punch
2. I've had tried virtually every volume setting between the WA33, Dave, and Jot R. SQ is even worse with just the Jot R. I've searched this thread and have tried every recommended setting or change. There's a bit less with some positions than others (WA33 @ 9-10 o'clock, Jot R @ noon for example) but still an issue
3. I could assume I have a defective unit, but the amount of consistent calling out on this issue when searching this thread suggests otherwise. Or, if it is, and all of the others also were then it suggests an even larger issue
In any event, I'm going to contact my dealer today. I'll be sending this back if possible and exchanging with an HSA1b asap. I have no desire to try another Jot R unit--at all. And again, can't wait to actually give more detailed impressions and comparisons regarding the K1000, 009, TC etc.
