FLTWS
I have no issue using the Loki's 20Hz band for those recordings that sound more satisfying with a little extra oomph in that bottom octave. Not all recordings need help, seems to depend on the engineering at the recording session. The problem with EQ is the usual application of "if an ounce is good a pound must be better", and it's just too easy to over do it. I spent this past weekend comparing the Balanced input with the SE input with Loki (both inputs driven by Yggdrasil 2), in on my HSA-1b. My thought processes tell me the Balanced input should sound more transparent but it just wasn't that much, if any more, to my ears. And the added oomph when needed was the difference between wanting to listen and not being engaged in the process with those CD's I felt needed help. Initially I thought that CD's from analog masters were most in need but I listened to a few that were over the top with bass. There is the probability that when the original session tapes were remastered for CD the frequency response was re-engineered to pump up the bass. (Being CD only I have no experience with EQ programs available thru the PC for downloaded content).
On a side note; I wish the volume control detentes had been built in 1 db steps instead of 2db steps between 10:00 and 2:00 on the knob. I was not able to get precise db readings between the Balanced and SE inputs.
