FLTWS
Danny from Requisite has said earlier in this thread that the aluminum piece is meant to be bent. It won't break.
My experience also, it looks thin and possibly fragile but I've bent mine hard with no issues.
The interface box recommends at least 100 watts per channel. I haven't tried the box yet, but the Jotunheim R sounds really good. You can get that combo direct from Raal.
Doing some research now, but it seems like some are using speaker amps? I know my amp (wa33) is efficient enough to power small/efficient speakers.. could I potentially use them with it? Please forgive my ignorance lol, I will do research now and have combed the thread a bit.
Quite intrigued by impressions I've seen, just didn't want to have to add another amp if I don't have to.
Edit: nvm.. think I just realized that I can with the interface box and the right cables. May consider that.
You either need the Jot R, the HS1-a, or a 100W speaker amp with the interface box.
It's really inefficient with the interface box because most of the power is dumped into a bunch of resistors, in order to present a high enough impedance to the amp. The dedicated ribbon amps are more efficient.
If you don't wan't to spend 30K, seriously look at the uberamp. Otherwise go for the HSA-1b.Doing some research now, but it seems like some are using speaker amps? I know my amp (wa33) is efficient enough to power small/efficient speakers.. could I potentially use them with it? Please forgive my ignorance lol, I will do research now and have combed the thread a bit.
The cans first? I had thought you had them. Sigh. They are the inverse of the TC.Yea I think I'd like to hold off until I see how I like the cans first. But the HSA looks pretty interesting.. I was reading the thread and noticed the b. So the will be temporarily unavailable until the b releases later in august? Is that right?
I'd grab the SR1a/JotR combo as a placeholder for the upcoming HSA revision or planned RAAL tube amp. I'd also be not surprised if a few boutique headphone amp builders designed a headphone power amp for these.I'd love something I could directly mate with the GSX mini I already own or in your case the Woo and use these are a pre.Yea I think I'd like to hold off until I see how I like the cans first. But the HSA looks pretty interesting.. I was reading the thread and noticed the b. So the will be temporarily unavailable until the b releases later in august? Is that right?
Nevertheless look at your alternatives. Sigh. If you want a pretty-great easy-solution, there is the compromised Jot R. IF you desire to ditch the compromised box,
look at your direct-drive alternatives.
Aside: looking in the alternative, chasing THE ultimate; from my experience, a Pass Labs Xs 300 leaves me wanting -- from a reference of 009+T2 (in context of speed and resolution,) ( the bass presence and, eh, image solidity, or, er, over-all sound presence (dynanicism) goes to the TC. DUH!!!!
However, if you are desiring to bottleneck the SR1a, you are easily looking at $30k. Sigh. But look at the HSA-1b -- from what you can gleam, and understand electronics (hint: the heat-sinks,) ALL available alternatives, (whatever your BS bias including mine,) directly bottleneck the amplifier. In every carnation including the upcoming tube HSA compliment.
Yes, I come from the Cult of Gilmore (with good reason.) Simply look at his direct-drive alternative designs to, well, the relative state of STAX.
Aside: without controversy or drama of blas-criticism, look at the response of EC Elektra ( DOG schiit,) ( which I bought,) ( CA LL, and study its incarnations.)
Aside: Yes, relevant BHSE hasn't received as lauded legacy, (however it is separate from KG "lineage".) Do remark KG "lineage."
Understand your direct-drive alternatives will not be of lore.
You will have to adapt an interface or an alternative "Cult DD."
Let's actually see (aside from the compromised Jot R,) the internals of the HSA-whatever -- and draw...bridges. This isn't an entirely new idea -- far from it. So you know.
And yes, I get most consumers won't get it ( especially the full-lineage,) however, it is a fact of '"truth."
Also, yes, feel free to PM me to discuss things further (and to keep the sheep bleating.)
As per @number1sixerfan's discussion, there really is no SR1a full potential.What’s your point?
An $800 placeholder for one month?I'd grab the SR1a/JotR combo as a placeholder for the upcoming HSA revision
