Aleksandar R.
Sponsor: RAAL 1995
The minimum, which I have here, is 2.5W. It's not quiet, but it just won't pass high peaks without clipping, so the satisfaction depends on the choice of music.Hi Alexander,
thanks for your answer. I had a curiosity, I use a tube amp with 2a3 valve, about 4 watts with 8 ohm output, but with the new ecla ca1a interface the volume is low, the Schiit jotR is a monster of power, there are minimum watt requirements and output impedance to make the ca1a work well with the ti1b?
The power I'm talking about is what is developed by the amp at the chosen input of the TI.
For example, if the amp makes 5W at 8 Ohms, I will choose the 16 Ohms, where it will develop 2.5W.
If the amp makes 2.5W at 32 Ohms, and its not specified that it will work at 16 Ohms, I would choose that.
I don't know much about DNA amp, except what I can read in it's specs. It says it makes 1.8W at 50 Ohms and 900mW at 100 ohms. It doesn't specify any lower load impedance than that.
So, of it makes 1.8W at 50 Ohms, it just might work with 32 Ohms input on the TI, with increased power, but also increased distortion.
Also, there are some gain and output impedance settings.
I wouldn't be trying the 120 Ohms of output impedance as the TI doesn't have enough primary inductance to "couple" in bass at this high output impedance.
So, I'd try 8 ohms of output impedance at full gain and 3 Ohms of output impedance at -6dB gain (and crank up the volume).
BTW, I don't know how it is possible to choose the output impedance if there's really no feedback...Maybe by decoupling some Cathode resistors, perhaps...
Stay updated on RAAL 1995 at their sponsor profile on Head-Fi.
