I don't disagree in the least with your definition....
And, because our eyes are optical, it's pretty easy to do that with a piece of glass.
I can look directly at a variety of actual objects and scenes, "switch" a piece of glass, and a blank frame, between my eyes and the scene, and see if I can tell the difference.
Windows glass is pretty clear, but you can still tell it's there, because it's never quite clear, always has a tiny bit of distortion, and always picks up reflections under some lighting conditions.
Under most conditions "museum glass" really is so clear that you might actually walk right through it, or try to put your hand through it.
However, since we analog humans have no way to listen to the bits directly, there's no way we can simply switch a DAC in and out of the signal path to see if it makes a difference.
But, since what we're really talking about is reproduction, taking an analog source, converting it into digital, then back to analog, will do fine.
If the result is indistinguishable from the original then we can reasonably conclude that the entire reproduction process is transparent.
(It's possible that the two conversions have complementary colorations that cancel each other out - but, as long as the entire process is transparent, that's OK.)
The problem there is that I'm unaware of anybody demonstrating to have been able to make a digital reproduction so perfect that nobody can tell the difference at all.........
(And, no, "most people", or "a bunch of people" doesn't count.... it has to be either everyone, or a big enough group that we can reasonably believe they represent "everyone".)
Now, interestingly, while proving perfection may be difficult, proving the opposite is often somewhat simpler.
If you have five DACs, and you want to claim that they're all "transparent", all I have to do to prove you wrong is to be able to hear
ANY difference between
ANY two of them.
(If two sound different, then they
CANNOT both be "perfectly transparent".)
I simply don't accept your claim (without proof) that any specific DAC is "audibly transparent".
And, while there have been many attempts to make "the perfect low cost DAC", and many have turned out quite well, I'm not aware of any that has been" audibly perfect" so far.
(I haven't even heard the perfect high cost DAC - at least not that I know of - but I've certainly not heard every DAC ever made.)
However, I do tend to notice small (and sometimes not so small) differences between the various DACs that I have heard.
You claim: "A DAC can be built for under $100 that is audibly transparent."
I eagerly await your proof.
(I'd probably buy one.)
If you must have an analogy for my use of transparency, than it would be "invisible". You can't make something more invisible. A DAC can be built for under $100 that is audibly transparent. There is nothing better. I'm thrilled that there are a cornucopia of consumer choices available that cater to practically everyone's system and ego, but I'm not convinced that any of these offer greater sonic transparency with regards to the thresholds of our hearing. Different, perhaps, and maybe even more pleasing to some people, but not more transparent.
