Ironically I’m not a huge fan of the cross feed. It’s an incredible DAC though. I run the Quicksilver from my Conrad Johnson’s Tape Out so all sources go to it.
I’ve always been a “purist’ so to speak, but I’ll admit there are some sources that could benefit from EQ
I’ve used the EQ and tone a little but at normal volumes I run it flat and it sounds awesome At lower volumes the Loudness contour is the best I have ever heard. It is adjustable in that you can adjust where it takes effect. The contour tapers off as the volume increases above the preset dB level to a point where it does not affect the output
Another cool thing is that you can adjust the dB trim of the contour. Out of the box it is set to +7 Bass and Treble. For me + 5 was better. It sounds great at night and at lower volumes. I replaced a NAD M51 which was great but no front panel volume. 7 years old, remote sucked. The RME remote is awesome. Can be reconfigured for your favorite features. It’s a great DAC and probably better than many “audiophile DACs at twice the price.
