Hey Guys,
wondering what tubes everyone is using with this beauty? Can it be tuned to be more euphonic without sacrificing the other qualities?
Does changing the tubes make a significant difference?
The RCA black plate 12AT7's do exactly this for me. Most forward, wet, warm, and natural mids I have heard on the amp so far. Definitely an unashamed n shape tube fr response, but with better technicalities than stock whilst also sounding a bit more lifelike. The highest extremes do roll off a little bit on both ends though, but the tradeoff is definitely worth it for me. I'm really, really happy with this pairing along with the stock jj el84's.
Prior to using those, I also really enjoyed the Baldwin branded Matsushita 12au7's. Neutral but warm tilted, better FR extension than both the stock tubes or RCAs, and also significantly more natural sounding and less etched than the stock tubes. They don't draw me in quite as much as the RCAs though, mostly because I prefer little more warmth and mids bloom.
The stock 12ax7's are... well, they don't make the amp sound bad, but they do limit it a bit I think. Sounds more solid state, not as natural, a little etched and rough around the edges.
For output tubes, I've only tried the stock JJ's and the Mullard New production EL84s. The stock JJ's are fine, pretty good actually. I can't really point out faults with the JJ's yet as I've only heard things that are worse. The NP Mullards EL84s were a step down in basically every way from the stock JJs, in technicalities, naturalness, air, extension, bass quality, everything. YMMV.
Now that I have some input tubes I love, I'm going to try to roll the outputs one more time with a pair of early 60's hammond amperex organ pulls I just found on ebay.
As it is, I'm loving the QS with the RCA's and the stock JJ's. and don't really feel the need to change the sound at all, just curiosity now
Using it with HD6xx's and HD800SDR
