Haidar
- Apr 1, 2004
http://www.questyleaudio.com/en/content/?73.html
Discuss...
The SATRI circuit is a current gain stage. What is being talked about with these headphone amps is the output to the headphones themselves being in the current domain. What Bakoon, Krell, Audio-gd and others do in most amps is have the amplification, and signal transmission between components entirely in the current domain instead of the voltage domain until the last stage before the headphones or speakers where a I/V converter is used. As far as I know, current-output headphone amps can only be used with headphones that have a completely flat impedance curve, such as orthos.
I thought about getting one, but the marketing fellow there seems to think that the CMA800 is only optimized towards the HD800 and similar high impedance headphones. Kept trying to steer me to the cheaper CMA600 model with the appropriate output module for my lower impedance HP suite (T5p, TH900, LCD-2). So I'm not sure how flexible the CMA800 is at this point...
Trying to talk him into a factory mod (1 low gain HP outlet + higher gain (e.g. HD800) HP outlet), assuming that they're equivalent now.
I may just pop for one, anyway. Questyle offered me attractive pricing as factory direct.
However, what time frame will you be reviewing the CMA800? I assume that you'll also be reviewing it with some low impedance cans.
The HD800 has a very fluctuating impedance curve, but the HPA-21 was still the best solid-state amp I've heard with it. While the pairing with LCD-3 was very good too, I felt the HPA-21 performed better with HD800.
