AzraelDarkangel
- Dec 28, 2006
I've had the DT880 Pro (250ohm) for about 2 weeks now and probably have around 20-25hrs on them. My previous headphones were Grado SR80i which I only listened to once since I got the DT880's and haven't bothered since as I've decided the DT880's are far superior in every way. I've heard they scale up nicely with better amplification and plan on getting an Objective2 amp and sometime later a usb dac. I have a tough time finding any deficiencies in their sound as they are the best I've heard and nothing at a reference level to compare them to. I have modded them though by removing the filter covering the backside of the magnet which the DT880 has but the DT990 doesn't have. The difference is subtle to me but I feel they now have enough bass where they felt just slightly deficient before (in the lower bass). The filter is easy to put back if I ever wish to do so. There is a mod thread which shows the differences between the DT880 and DT990 and it comes down to the filter in the back to attenuate the bass and a circular piece of felt over the front of the driver behind the earpiece foam to attenuate the treble.
I do feel there is a slight lack of something but it's hard to nail down, maybe a bit of air and space? It's probably just an amplification issue. How much change do you get with various amps and DAC combos? I almost want to remove the felt but I think it's glued in so it would be more complicated to put back. I don't find the DT880 too bright at all, but neither do I think it's dark or dull, just sounds pretty well balanced. Not sure if it's worth messing with before I have a better amp. The only other mod I plan is mass dampening the back of the magnet (careful to not cover any holes) and the inside periphery of the cup with Tungsten putty. What improvements did anybody find when moving to higher end headphones?
Joshua
Joshua
