Mar 29, 2013 at 4:17 PM Thread Starter Post #1 of 1
imeem
I planning to buy a sub for my A2 and the S8 seems like a logical choice since it's from the same company, but it's sumwhat too expensive.
I'm currrently looking into these 2 sub:
1) the S8. I heard that if i connect it to my A2, the crossover will not work with RCA
[size=14px !important] Does the crossover on the S8 adjust the frequencies played by speakers connected to the RCA line output?[/size]
The S8's crossover is a variable low-pass filter, and will not adjust the audio for the RCA output connection.  This is a full range line level output.
-does this apply to 3.5 mm jack
-and doesn't this mean that the overall bass with this 2.1 setup will sound bad?
2) PBX (PowerBass) PBX-8.1
-Is this a good sub for the price?
-I assume it works with the A2 and i just connect it the same way i would connect the S8?
-Also, does this sub have the same "problem" with RCA and crossover?
Here's a clearer image of tge PBX's rear:
http://www.mobilesoundworks.com/PhotoDetails.asp?ShowDesc=N&PhotoNumber=5&ProductCode=PBX-PowerBass-PBX-8.1
