Mar 2, 2014 at 2:45 PM Thread Starter Post #1 of 2
tidan31
Hello! I have a player of a fiio x3 impedance he takes the exit is 16 Ohms - 300 Ohms and I have headphones in ear of shure se846 Impedance they spend exit is 9Ω soon as I hear the volume relatively high I feel jarring ears and down low I can not hear any well whether the match I made the headphones and the player is a good match and if so what is the problem that I do not hear well (clean) and if not then what do you recommend I do and is there a connection between the player spends impedance and impedance headphones spend please help me I'm desperate
Mar 2, 2014 at 6:08 PM Post #2 of 2
Well, source output impedance indeed affects the way headphones sound, however it's not your case as FiiO X3 rated less than 0.3 ohm. I believe it's perfectly fine for SE846 (note I don't own them or X3) :3
