Question about volume settings on DAP connected to an amp.
Jan 29, 2008 at 1:37 AM Thread Starter Post #1 of 5
philthy
Hi. I'm new to using an amp with a DAP and I'm wondering if you adjust the volume on the amp or the DAP when you're listening to music. For example would I leave the volume on an iPod at a certain level and then adjust with the amp? Thanks!
Jan 29, 2008 at 1:42 AM Post #2 of 5
If you are using an ipod you really should be using a line out dock, but if you are unable to get a line out you should have volume on DAP at full (unless distortion occurs) and control volume with amp.
Jan 29, 2008 at 1:46 AM Post #3 of 5
I've tested numerous daps on the woo6, full volume and controlling from amp sounds best. Test pausing the music to see if you hear any sound/buzz, if so, lower the volume on the dap. And as Gautama said, if you have line out use it.
Jan 29, 2008 at 10:20 AM Post #5 of 5
Set volume to max and when clipping occurs (which I doubt, it's iRiver
), lower it till the clipping disappears completely.
