Pyriel0
- Nov 6, 2008
I wanted to test a balanced signal in only the right or left driver of my headphone to see if its worth the cost/trouble to buy another amp and redo the cables myself for balanced. I would have the inverted signal hooked up to the ground of the headphone and the positive to the normal + side for driver being tested. If I am testing with the right speaker, will the impedance of the left screw things up(since the ground is connected to both)? I don't think it should since the left speaker will be left open. Only the right speaker would be a closed circuit. I just wanted to ask and see if someone could tell me for sure before I try it. Thanks
