I am sure that's the case, but when I was looking at amphead's web site there was very little info on what went into the amp. Yes if Justin listed the "DACT stepper" I could have looked it up, I have a Alps RK50 in my WA5LE so I know what it can do, and yes my fairly heavily modded WA5LE does also run hot so I know what to expect from the heat.
No you are wrong about how the Realiser works when doing a HPEQ, the Realiser is not really a EQ in the normal world. What it does is measure response's time basically for sound staging and balances the right and left ear cups for the shape of your ears and how you hear these sounds/test tones. Its for this reason why my HPEQ probable would not work for you, just as the PRIR would not work for you. However there is a manual HPEQ setup in the Realiser but mainly it is to better balance the sound-stage R/L/C/Sides/Rears and SW coming from the headphones. The same goes for the PRIR's and it is when you make a PRIR of a sound system is when you would do a manual HPEQ, at least for best results.
The whole Idea of the Realiser is to copy the sound system and room acoustics, not to EQ or change it as a real EQ would do. However yes you can do some manual EQ but imo that really detracts from what the Realiser can and should do.
To put it simply the Realiser developed by Dr. Smyth (the creator of DTS) is to copy and balance a sound-system not change it, and in part using the Binaural type of recording technique but in the Realisers case it uses your body, head and ears not a dummies and then also is able the add a MCH speaker setup so you get the sounds coming from were ever the speakers are placed when you did a PRIR
