Incrementum
- Oct 23, 2012
EDIT 1 - Decided on going with the Beyerdynamic DT 990 Pro w/ a Titanium HD sound card.
EDIT 2 - Looking for an amplifier
The AKG's KQ701/2's would be ideal for what you're looking for but they don't have much bass. They do have a fantastic soundstage which perfect for gaming, movies, and for certain music genres. They have quite a neutral signature with a slight treble emphasis. They also need a lot of power to come alive so a decent amp would be needed. The D2000's may be better for you if you want more bass.
How much would a decent amp cost me? Any suggestions?
Save a few dollars, used HD558, $150, or less.
http://www.ebay.com/itm/Sennheiser-HD-558-/160907463178?pt=US_Headphones&hash=item2576d50a0a
refurb Creative X-Fi Titanium (non-HD) PCI-E sound card, $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102043
So, for $200, or less, you good to go.
Later on if you feel you want to add an external DAC/Amp.
SMSL SD-793II optical input DAC and amplifier. $60
http://www.ebay.com/itm/280993199312?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
So the sound card acts as an amp? Is there any downside to this?
What if I went with the Sennheiser HD 598 and E7 for the amp / DAC? Would the E7 be able to power the 598?
I'm not a big fan of buying previously used electronics
The Q701s hardly have a neutral sound signature - the sound is skewed towards the upper mids and treble. "Slight" treble emphasis does not equal peaks in 2khz and 10khz. Like you said, their bass is very lacking and while they are fantastic for positional audio, they will make explosions and thumps very unrealistic and underwhelming.
The HD598 is a very good balance between supreme positional audio and game enjoyment. The bass is very close to neutral and HD598 can produce a lot of bass when it's supposed to be there. The D2000 is another viable option but their treble is quite strong, and their bass detracts from proper positional audio despite having a decent soundstage. And I'd take the HD598 simply because it was (imo) more comfortable and lighter.
Virtual surround sound makes things sound more 3D. A lot of soundcard offers this. I'd recommend you invest in one and get a separate amp.
