bahamot
- Sep 17, 2005
Last time I asked, QLS wasn't ready to sell overseas yet due to high demand in China. So, English reviews or impressions will be hard to find.
Looking forward to the pics and some more impressions on the sound.Just arrived. Very interesting but not sure if my Cup of tea.
Will post some pics since there are almost no data about this DAP in the western world
So far I can just tell you that:
1) it does come with some interesting items, like a 32G sd, a leatherette cover really nicely made, and above all a very useful adapter cable with 3.5 to 2.5 balanced terminals, meaning you can use a 2.5 balanced headphone with the 3.5 balanced output the DAP has. Essential for me since I have the IT04 from iBasso
2) there a tons of settings and fine tuning, like to possibility to choose between "mellow" and "bright" tuning, plus the classical "slow" "sharp" and an interesting "all to DSD" mode too. very easy hence to find the tuning one does prefer.
3) building seems really solid, DAP is sturdy without being "a brick", physical UI is very intuitive and in general the layout is ok: I'd only point out volume control could have been implemented better (it's justa a simple bar, when the cover is on you barely can feel where the "+" and "-" are). Plus when you lock buttons it seems as if you lock everything except volume bar, where I would have liked more the possibility to customize a little this (i.e. on some DAP you can set that when locked, you can long-press the pause/play button in order to make it work, etc.)
4) internal UI is pretty straight, very "barebone" indeed: it is a philosophy Ilike, since I love just to listen to music and not fiddle around with features but some of us might find it a bit poor perhaps. For sure it is quick, boot time with a proper sd and 256G (which btw is already "big" in terms of what QLS suggest you to use in terms of best performance) I must say it takes around 5/7 secs to be up and runninng.. not bad
5) screen is ok even though is very "vertical oriented" meaning that i.e. long title takes ages to be read, plus personally I'd have opted for a more clear font, but this is personal taste.
6) power: I haven't tired yet the Line out /optical, in general both PO and balanced are not bad at all, with my IT04 I often run around 30/100 up to 50/100: over 50 it becomes really loud. I'll try asap with more demanding full-size hp to see how it scores.
I won't enter into sound details since I am not such an expert: I think in general it is very detailed and the "punch" (given the right "feed") is good. To be honest though I am making some comparison with my other DAP, an AUNE M2 PRO, and the differences I am finding makes me still lean over the latter. Question is I've found the balanced output (main reason I wanted to try the QA361) is probably "not my cup of tea", as I wrote at the beginning. Let's see if this is a keeper then.
Picture asap!
The pure version firmware is available in two versions for download. The two versions of the sound are more transparent and smoother than the general version, but the two styles are slightly different, and the user can install both into the card. Then compare the audition and choose.
Download address:
WAV 1.0.4: http://www.qlshifi.com/qa361/QA361-WAV_v1.0.4.rar (horizontal sound field is larger than the standard version, more ethereal, musical instrument sound distribution and vocal basic balance)
WAV 1.0.5: http://www.qlshifi.com/qa361/QA361-WAV_v1.0.5.rar (The sound field size is similar to the standard version, but the vertical level is more stable, the vocals are slightly more full, the sound is more compact, and the emotion is more concentrated)
It arrived, it arrived, it arrived!
Can't wait for the reviewIt arrived, it arrived, it arrived!
Update 2: 10-October-2018
Whenever I get new daps, I test it with IEM I'm used to, and they go about like this. Ultrasone IQ ER4S, Dita Truth, EX-1000, Kaede II, Hum Prisitine. Issue with QA361 is that the stock FW plays DSD and Double DSD and the WAV FW which has two styles, and the popular one due to better sound, doesn't support DSD.
In stock FW, I'm really enjoying the sound of DSD. It has this organic sense to it that is very similar to LPG. I strictly use LPG for a DSD DAP as I find it best suitable for DSD. Once I'm familiar with this DAP, I will focus on stock FW testing and than move onto WAV only FW, which is where this DAP shines best.
The qa360le isn’t mine, if I can borrow it again I shall do so
