T.R.A.N.C.E.
- Mar 24, 2010
Any impressions on the QA360LE?
Having listened to "Claire Martin We've Got A World That Swings" ripped from CD I completely recant my criticism of the DAP, it's not clinical, it's accurate. I haven't heard a piano reproduced so accurately from any recording until listening via the above setup; the last time I heard a piano sound this good I was in front of it (not playing it though).
Personally I'm not interested in the DAP as a DAP, I'm using it as a digital source and to that end it's phenomenal.
Interestingly the Mojo/Ray Samuel combo really blows away my Naim DAC VI; time to get the Chord 2qute I think.
BTW I've listened to all the firmware, both WAV only and full, I prefer the as supplied with my unit firmware (as of May 2016) full version 1.306.
Can't wait for my QA360LE to turn up. ^ Yeah it really is a fantastic source, best I've heard at any rate, really makes my NAD M51 turn out the most analytic effortlessly detailed sound, but in no way strident or edgy, its just pure smoothly rendered detail that instantly gives you the impression of 'this is the meaning of colourless sound', it maybe a touch sterile, but not in a negative way, it really can't be helped when your outputting this much much smooth detail. My more engaging sources like P90SD have a particular toe tapping factor to them, but don't quite impress like the QA360 when it comes to detail effortlessly laid bare. You can't both have your cake and eat it.
Optical out to MoJo is also very good
So, you can actually hear a difference between using the Mojo, vs just coming straight out of the 360? Any details you could share on the topic? Thanks!
I use the 360>Mojo>Ray Samuels>Senheiser HD25 1-II (since I don't like the Mojo headphone amplifier) or 360>Mojo> Schiit Lyre 2>Beyerdynamic DT770. The Mojo/Ray Samuels combo is effortless, dynamic and transparent through the Senns. The Mojo/Lyre 2 combo into the DT770s also has a really dynamic sound with tons of authority.
The on-board DAC is good, but the on-board amp isn't good enough to bring cans which are capable of good dynamic behaviour to life; plus the Mojo is better than the on-board DAC. I'd also say both the aforementioned combos are also a good step-up in transparency compared to just the DAP.
Listing to QA360LE, I really love it from first listen, but probably should burn it in before giving impressions.
