Ward
- Sep 7, 2008
Ok mate nice one, thanks for the advice.
Originally Posted by jiiteepee /img/forum/go_quote.gif Hmm... maybe just to choose source channel ... as Audacity is not ASIO compatible software, you maybe need to enable the port you have connected your external gear through system recording options (start run... sndvol32 /r). If you can set the source port through Audacity then if there aren't audio after setting the port then check the system recording settings as instructed above. jiitee |
