RockStar2005
MakeMKV is free while in Beta, there is a temporary code you can use to activate it in the forums, they change it every 30 days or so I believe. If you like it you can also purchase a permanent license.
AudioMuxer is 100% free with no license required, if you use it then you don't need DVDAE at all. Yes, DVDAE can read unprotected Blu-ray discs.
For the upcoming Zep disc, I will back it up using MakeMKV then will use AudioMuxer to extract the 5.1 tracks to FLAC. Then I'll run the DR meter on them and upload to the DR Database if no-one else beats me to it.![]()
Haha ok thanks dobyblue! MUCH appreciated!
![L3000 :L3000: :L3000:](https://cdn.head-fi.org/e/headfi/L3000.gif)
