SearchOfSub
- Aug 28, 2013
That would be PCM. Damn that auto word func.
Don't understand why owners of DS over at PS Audio is using JRIVER or a software program to source into DS on PDC files... isn't the main purpose of DS the converting factor of all PDC to DSD? I'm only pointing this out because I plan to get the DS next month.
Crashem did you get your DS yet?
Welp, got the kit in at the same time as my airmotiv 6s speakers and herbies audio super stabalizers. Sadly I managed to yank one of the ac wires the wrong way and the wiring pulled out of the terminal, but I think my ratshack replacement faston terminal should do the trick. Went to my calc class just after it happened and couldn't focus at all...
I'm waiting on the Direct Stream to burn in more/spend more time listening before making any critical judgments, but it sounds very very good. The main problem the airmotivs have is with how sharp the treble can be at times, but it's gotten comfy after just 4 hours of burn-in. Still a bit direct at times, but better than with the mk2. Detail retrieval leaves nothing to be desired and is excellent. Also just updated to the 6115 firmware, but everything is so new it's hard to tell any differences. The airmotiv 4's responded well to hifi tuning supreme fuses, so this time around i'm going with the much cheaper AMR fuses, considering i've read how they relax the sound without letting details slide. Not sure if the new herbies stuff is doing much of anything though. Or where to place them. Have one over the transformer and one over the digital stage.
