Matthewlawson3
Hi, a few years ago I ripped my CD collection to FLAC files. Recently, I got into DAPs and have the Hiby R6 Pro on its way. Looking at my ripped FLAC files, I see that I ripped each track with Exact Audio Copy at 44100 HZ at 32 bits per sample (according to VLC). Adobe Audition says 44100 HZ 16 bit depth.
The question is do I need to change some settings in EAC and re-rip to get the best quality out of the tracks or is that as good as is it will get? This is in preparation to transfer them to the R6 Pro when I get it. Also, would you recommend another Ripper for Windows 10 or is EAC fine?
Thanks!
Thanks!
