CZ4A
- Aug 26, 2015
I've done a little rolling lately with a couple of tubes that I haven't seen used in any Garage1217 amps yet- the 6C8G and 6F8G! I have a T-S round plate black glass, Raytheon, and RCA 6F8G and Ken-Rad and Sylvania 6C8Gs. I have listened to them all and I am happy to report they sound fantastic in the Sunrise! They look cool, too. Here's the Ken-Rad:
However, all of the tubes have an annoying buzz in the left channel audible when the volume is low. IIRC the 6F8G family can be microphonic, but the buzz is consistent across all of my tubes, the right channel is not microphonic on any of my tubes, and the left channel happens to be the capped triode which (again IIRC) should be more isolated from interference. I wonder if the issue is the eBay 6F8G to 12AU7 adapter. If I touch the adapter or the grid wire the buzz gets worse. Also, it is really wide. It barely fits through the tube opening in the top cover and doesn't fit all the way into the amp's socket because it sits atop the LED jumper! Removing the jumper lets the adapter seat properly but does nothing to reduce the buzz.
I might buy or try to make a 6F8G to 6SN7 adapter but that leads to a Leaning Tower of Adapters. I'm also thinking of getting another Garage1217 6SN7 to 12AU7 adapter and modifying that, but I am a bit concerned that cutting traces and splicing wires in their place to match the 6F8G pin out might introduce cross-talk.
