Stonez
- Oct 7, 2011
Hey guru's. I'm at a place where I want to expand my audio experience out a little wider and need some direction in how to spend $300 . My musical tastes are diverse, but I mainly listen to jazz, electronica and rock/metal. I have a variety of low end head gear that I use with my iPod Touch (2nd gen):
Sony MDR NC-22 (mowing the lawn)
AKG AQ350's (running/working out)
Audiotechnica ATH-AD700 (fave @ home)
Senheisser HD25-1-ii (fave on the move)
I also have a FiiO E5+L9 LOD for my iPod and a regular line out cable that I use with my Samsung GS2 Epic 4G touch running PowerAmp.
Now I need to decide whether to expand my headgear range, or get a new amp/dac. I listen to a lot of music whilst at my computer using my 700's, but I'm running them straight off the audiochip (Realtek ALC892 codec) on my motherboard (which is really ****ty and has a occasional extended bouts of EM intereference), using foobar2000 + wasapi. It can sound great at times but it never feels all there... Would I benifit more from buying a dac/amp or a soundcard here? I was looking at the FiiO E17 vs an Asus Xonar soundcard or comparible.
I also spend 2hrs a day commuting back and forward to work (and I park and ride) and that's when I'm using either my iPod or GS2 with my AKG's or HD25's. Would a portable amp ie Headstage Arrow HE 4G be a significant improvement over my current setup or again, would the E17 be a better all rounder. As can be seen, I am biased towards getting the most out of my current headgear but would a better set of cans be the best place to widen my audio horizons? I look forward to hearing from you.
tl;dr Amp, amp/dac or new cans and I have $300 to spend
