Trogdor
Reviewer: Metal-Fi
- Feb 1, 2004
The size of the unit is quite nice, really compact and can easily be placed on one's desktop. Also, notice the two blue LED lights. The blue LED on the left is for power, the right is for USB connectivity (always on even if you are not using the USB input but connected).
The craftmanship of the unit itself is very impressive for $400 USD. Its got some weight (official 2.2kg/4.8lbs.) to it which is quite surprising considering its size. Also the volume knob is quite cool, large and very easy to adjust for completely control.
Okay, so after listening to it for about 3 hours we have run into a major problem. Through the USB using DirectSound, everything sounds normal and generally pretty good. However, through the analog inputs from either my SCD-1 or Apogee, there is a distinct hum that we pick up on the Qualia's. What's worse is that on some tracks (e.g. No Doubt's "Hella Good") there is a noticeable dip when Gwen's voice moves from the left and rigth channels - its really really bad and seems to only happen through the analog inputs. We tried this with and without crossfeed but the problem remains.
Has anyone else experienced this issue? I've advised my buddy to contact Meier about it regardless but I just want take a quick poll. We are not sure if the hum is natural and the dip is just the way it is or there is something funky going on through the analog inputs. He was one of the first to order so it wouldn't shock me terribly if there are some glitches in the first production run (I'm quite aware Meier makes some high-quality products).
