Zafsk
- Jul 9, 2009
Hi,
This'll be my first post here. I just received my FiiO E5 and it worked perfectly when I started using it, and then I decided to play with the volume on the amp itself. I turned it down a bit, that worked, I turned it back up and I didn't notice any change. I shrugged it off.
However, when I went back to turn it down further it dropped dramatically like I wanted it to, but I couldn't turn it back up. It is now currently at it's lowest volume and I can't really turn it up.
I'm curious what the issue may be, and if anyone could help. Considering disassembling it, but I'm not sure what to do from there. Thanks for any help.
