Problems with D-25s
post-185335
Thread Starter
Post #1 of 10
bengt
I've just got me a Sony D-25s, but it dosn't really work.
When I plug it in to my 9V 1200 mA adaptor, put a cd in it and press the playbutton, the screen is just lit for some seconds and then the unit turns off again.
Do anyone recognize this problem? I haven't jet got the battery, can it have something with that to do?
post-185343
Post #2 of 10
elnero
Prince Edward Island, Canada
It sounds to me like it's not recognizing the CD, have you tried different CD's with it? Just a thought.
post-185345
Post #3 of 10
RVD
I agree with elnero, the D-25s does the same thing when there is no disk in the player, so it probably is not recognizing the disk. Is the disk a CD-RW? That could be the problem.
post-185348
Post #4 of 10
bengt
no it's not a cd-rw and I have tried some different cd:s.
The cd doesn't even start to turn around which make me think that the cd-player doesn't even think that there's a cd in it.
post-185522
Post #5 of 10
HighwayStar
Won't excrete urine on your holiday (unless you do so to his first).
You sure the adapter's configured for tip(center) negative ? I don't have a battery for mine and it works with a 9V RadioShack adapter.
post-185645
Post #6 of 10
Ptrick
bengt,
i was wondering whether in the few seconds that the screen is lit... is there any sound coming out? i mean does it start playing the the first track of the cd or not?
post-185649
Post #7 of 10
millerdog
If you got it from silicon salvage, send it back for another.
If you got it used, try a lens cleaner.
md
post-185716
Post #8 of 10
bengt
well there is no sound in during the few seconds the screen is lit.
And yes i'm sure I've configured the adaptor right.
what happens when i press play is just that the screen is lit and on it stands 00 and ams.
I bought it from a person in the US who sold it on ebay. I couldn't buy it from sillicon salvage since they are not shipping to sweden.
post-186750
Post #9 of 10
JML
What you're describing is the behavior of a D-25S running off a battery that's too low to play a CD. The display lights up, the the disk spins, no signal comes out, and it shuts down. This assumes, of course, that you have a battery in the unit.
My suggestion is to check the AC adapter. If you have the plug reversed, as noted earlier, there will be no power seen by the player. If this is the Radio Shack adapter, when you look at the plug, head-on, you'll see the + symbol. On the reverse side of the plug, the - symbol and the word "TIP" should appear. If you have it set properly, the adapter might be bad, which is not unheard of.
Good luck!
post-186752
Post #10 of 10
Ptrick
Slightly off topic, but I just want to add that I've recently ordered a pair of the Sennheiser HD580's and I can't wait to hear them paired up with the D25s... such has been talked about on these forums and especially in Russ Accuri's excellent review. AAaaah... the anticipation....
