xTr3Me.aka.Chris
- Oct 4, 2007
Hey,
today Ive finished my Jisbos Buffers.. some hours ago I started to adjust the right bias but then I noticed that I do not have the right voltages on the main soha-pcb.
for example at the 60V testpoint I have above 100V after some time
Same problem goes with the two 40V points. since the voltages of the 60V testpoint is much too high I cant adjust the 40V voltage. I cant adjust it below 50V and 55V on the other control point
The voltage is growing per time.. now I turned the Soha off because also the tube is getting more and more hot..
Does anyone of you have an idea?
I havent adjusted the DC offset on the jisbos boards yet, because I havent found out where to messure. Might that be that reason?
greetings,
xTr3Me
greetings,
xTr3Me
