right ill try it tonight for a few hours and see what happens. Did the hard drives go back to normal, or were they just used to get the data of then thrown away?
Originally Posted by azncookiecutter /img/forum/go_quote.gif Apparently it gets the head properly aligned. The clicking sounds is usually the head of the HDD going back and forth. Been working in an IT department for co-op for a few months now, and the freezer is known as our personal data recovery centre for dead hard drives. Around 75% of dead hard drives, after the freezer, we've been able to recover most of the data off hard drives.
very nice information. you do learn something new everyday. had this kind of incident before, and i just gave up. would've been nice to know about this trick before chucking the hdd, and mopping for the loss of data.
I've done the freezing thing (put it in a static or ziplock bag first) for a dead drive and I've done spinrite and many more. Spinrite doesn't work very well with external drives for me and is very slow (put it in internally maybe), its never really helped. I have used Hiren's boot cd (shhh) in the past and it is amazing for the tools, but I would be concerned about its legality nowadays. When mine spins like that, even a slap on the top fixed it a bit. It probably is the enclosure.
The control board on the harddrive is what the freezing affects. You have to freeze it for at least three hours as you usually only get one or two chances to get the data off after that for about 30 minutes if it helps. It should only be a last resort. Enclosure or hard drive, either, you probably should try adding it as a secondary drive in a desktop. Run some diagnostics on it with some tools, I use a boot cd so that the OS does not mess with the drive contents. A good disk checker should be able to fix bad sectors so that it works good as new again usually. I hae never lost a harddrive unless it is completely bricked so that the platters don't spin. You have to stop problems before they become worse though.
Originally Posted by fault151 /img/forum/go_quote.gif No luck so far, I've tried freezing the hard drive, nothing happened. It still sounds like its stuck. Any ideas???
