88Sound
- Dec 14, 2001
Beagle,
This is exactly the trap I've fallen into, with a few caveats. I would substitute the word "correctly" with " to match my personal preference". The switch from SS to tubes seems to fall along a speed/power (SS) vs. Timbre/Thickness/Warmth (Tubes). When I'm listening to music I think sounds perfect with a certain headphone/amp combination it does not sound colored to me, it sounds perfect. This same combo that sounds perfect on some things sounds very colored on others. Maybe if I find the perfect headphone/amp combo, that will sound perfect on everything, but the search is expensive. At least most of the stuff is easy to swap and doesn't weigh very much.
Things are getting scary. I just found out that the Zeus amp is made in NJ, and not that far from me. If I audition that I may be doomed to yet another piece of expensive gear. Is it possible, a tube amp with all the strengths of tubes and solid state and none of the weaknesses? I doubt it.
Yes, I am crazy, but I'm having a lot of fun!
I find it hard to believe that a good amp can make a violin sound real and a vocal colored at the same time. Doesn't make sense. This seems to indicate we have to swap amps, speakers and headphones when we want to listen to different types of music "correctly". |
Beagle,
