Tomm11
Thanks. I see it now in one of their press releases as well ... "also supporting integrated DAC-amp output (economy mode) for excellent low power consumption and extra long play time."It does.
I stand corrected: it's the 25th see screenshot of HIBY Website...
The specs are listed by Hiby for economy mode and balanced is available. They spec "economy mode" power as 110mW SE and 320mW balanced into 32 ohm load.Any more info about 'economy mode'? What processes are running? I assume all android functions are shut down and it's running in 'pure music' mode with only the single ended output available. Will it be sufficient to run more demanding IEMs & full-size headphones?
I don't own a Hiby player but I heard something about that. Does the power drain occur when the player is manually shut down or in sleep mode?Are we going to see the severe battery discharge while off which is plaguing Hiby R8 in this model too?
It happens when the player is completely switched off. It doesn't seem to affect battery life while listening to music, but in my case the DAP loses 10% of charge per day when off. It's pretty inconvenient because I need to remember to top it up every few days so as not to allow a complete discharge that will affect the battery negatively. So for the sake of its buyers I hope the battery implementation in this new model is better.I don't own a Hiby player but I heard something about that. Does the power drain occur when the player is manually shut down or in sleep mode?
That's crazy. So something is draining the battery with the player shut all the way off. I've heard of this with some other players when in sleep mode but not when they are shut all the way down. And they can't fix it with a firmware update?It happens when the player is completely switched off. It doesn't seem to affect battery life while listening to music, but in my case the DAP loses 10% of charge per day when off. It's pretty inconvenient because I need to remember to top it up every few days so as not to allow a complete discharge that will affect the battery negatively. So for the sake of its buyers I hope the battery implementation in this new model is better.
Apparently not. This problem was reported here on head-fi a long time ago and none of the firmware updates has fixed it. To the contrary, I think it's become worse with updates, but I am not 100% certain of this. I recall that initially the battery drain while off was around 5% per day, but I don't remember if it was before or after I did the updates.That's crazy. So something is draining the battery with the player shut all the way off. I've heard of this with some other players when in sleep mode but not when they are shut all the way down. And they can't fix it with a firmware update?
You forgot to mention the apologists who will overlook material product flaws over some misguided fanboyism, brand loyalty or because they are downright shills.People, batteries drain. Just because you don’t like it and love to find fault doesn’t legitimize your attempts to dissuade potential customers. Every thread here Is the same. Announcement, excitement, detractors and doomsayers, griping with equivocation, debate, then impressions to which the cycle repeats. I hope to enjoy mine.
I also have the A105. I'm in Ireland looking for a new alternative that will last me for years to come. I've locked myself into Sony gear for decades apart from my Fiio X3 original, which I still have and use occasionally. I don't have any background experience of this manufacturer but this device looks very interesting indeedAnyone know how this company handles import duties and tax for the U.K.? At todays rate this thing is a steal and I’m quite tempted as an upgrade to my Sony A105.
Also, does hiby OS / Android support the likes of play store or is it specific apps only? I use Apple Music, Tidal and Poweramp EQ apps regularly so these would need to be fully supported.
