The TRIAD output circuit in this PPA 2.0 Version comprises a novel dc bias circuit, which comprises an enhanced complementary fully symmetrical current mirror to provide an Ultra bias boosting circuit for biasing the Driver and output transistors. This Sophisticated Bias arrangement makes the charging rate faster than the discharging rate for each respective half of the complementary Diamond Buffer output stage. The Complementary current Mirrors set the quiescent current of the driver and output transistors. This dc bias circuit comprises an adjustable JFET Constant Current source supplying a precise amount of DC current to both Positive and negative current mirror circuits at the same time and in precisely equal amounts. Each complementary current mirror simply mirrors the Current supplied by the Jfet Current source in precisely equal amounts and assures that each PNP and NPN half of the diamond buffer is supplied with exactly the same amount of current. This maintains True complementary handling of the Audio waveform so as to completely remove crossover distortion regardless of whether or not the load current is greater than the standing bias current,
Thus, we have a Ultra stable bias circuit capable of charging and discharging the Driver and output transistors with a charging rate faster than a discharging rate.
In a conventionally biased class AB amplifier, the average bias supply current increases as power increases. This increased average current results in an increased voltage drop in the resistive part of the bias circuit. This in turn reduces the average voltage drop across the forward-biased PN junction of the power-amplifying transistors, pushing the amplifier into class B operation Therefore, the output will be saturated as the output further increases in response to the Audio signal.
Linearity and efficiency are two contradictory requirements in a power amplifier. The tradeoff between the linearity and efficiency are the classic design dilemmas for the power amplifier designer. Therefore, This Buffer Topology is designed to provide a power amplifier circuit with a novel biasing scheme, which is simple but capable of maintaining good control of quiescent current for the power transistors.
By properly controlling current the output Transistors, the charging and discharging rates can provide the ideal bias current for achieving optimum Current gain and extended Bandwidth in the Output stage.
In this unique Bias Circuit, the jfet current source bias generates the bias current simultaneously to each complementary Wilder current mirror circuit to establish the drive current to each respective half of the diamond buffer. Thus only one current source is needed to control the quiescent current of Both PNP and NPN Driver and output transistors and eliminates the unequal bias currents of each half of the Diamond buffer that would result if two conventional current sources are employed like in the Jung style diamond buffers.
The most linear method of implementing a current mirror is to use a 1:1 ratio, thus 1 mA produced by the Jfet Bias generator results in 1 Ma output for the Current mirrors. In this manner thermal tracking of the Mirror is maintained without matched transistors since the power dissipation in each of the mirror transistors are the same thus the ultra Vbe of all 4-mirror transistor will remain constant.
For battery operation, the availability of current sources that operate accuratly in a low voltage environment is very desirable so as to obtain the most available voltage swing for a given supply voltage. A current mirror circuit will typically operate up to the saturation point of the Mirror transistors. This allows the output to swing to within 1 volt or less of the supply rails while still maintaining adequate bias current to maintain low distortion even at output levels approaching Clipping.
While more complex in design and requiring more component parts than a conventional Diamond buffer, the enormous benefits derived from applying Bias current in symmetric fashion to each half of the Diamond Buffer Circuit results in the ability to slew at very high rates and still retain a symmetrical rising and descending slew rates. This is very desirable to eliminate odd order distortion components known to result from improperly or asymmetrically biased Complementary output stages. The result over the use of two separate independent conventional current sources is a more smooth yet detailed reproduction of textures. Musical Peaks are presented clearly yet never thrown in an uncontrolled manor out at the listener. Control with detail and micro dynamics is just a few of the benefits that result by using this more complex “Ultra Bias” method of biasing a complementary output stage. Additional advantages are ultra low DC offset and an extremely high current gain resulting in high input impedance with equal input bias currents and thus make this buffer also suitable as a stand-alone Unity gain Headphone driver that will maintain its low DC offset even when the source resistance is quite high. This lends itself to use as a stand-alone Buffer that will allow you to build the PPA without any op amps and related support circuits. By simply jumpering the op amp non-inverting input to the output and not installing the op amp casscode constant current sources your PPA can be a unity gain feedback free headphone amp with an all discrete component signal path.
Different designers have quite different views on just want qualities are desirable in an Amp and thus you see quite different topologies coming from different designers. I designed this Circuit to obtain the absolute best performance and IMHO the best sound quality available in a battery operated easily transportable headphone Amp. If you desire class A or something else this amp is not I suggest you build one of the other many fine Amplifiers available online and not try to make the PPA 2.0 into something it is not intended to be, However I believe the PPA 2.0 will hold its own against any of the top quality Headphone Amps available, But of course IM Biased.
