morsel
- Mar 22, 2002
MisterX: The PPA is not designed to accept 16mm caps, nor do we suggest you use them, nor should you have any need. Using 12.5mm (1/2") caps you can pick from quite reasonable Panasonic FC or Nichicon PW or HE and easily reach 2000-3000µF. If you want to see all the C1 slots filled, use a lower value so you don't get too much capacitance. You can also choose 8×220µF Elna Cerafines for a total of 1760µF, or if you are using an oversized case, 9×220µF Elna Cerafines for a total of 1980µF.
We switched to the inline TO92 parts because the layout works better that way, as traces may pass easily through the middle pad. Standard TO92 parts must be hand bent to fit either triangular or inline pad configurations, but machine splayed parts are difficult to unsplay without mangling the leads, so inline pads provide the best parts compatibility. Triangular TO92 parts mounted face to face can not be bent aside to read the labels without badly kinking the middle lead, whereas inline parts may be bent aside with less trauma.
aeriyn: We will let you know when we have an ETA on boards.
Voodoochile: Traces from the left pot pads passed over the top side of the board across the landing area of the sharp landing legs for the middle pot pads. In the unlikely event that the sharp landing legs puncture the silkscreen squares and solder mask, they could short against those traces, thus disabling bass boost for that channel. The bass boost pot is part of the feedback loop, not an input signal, so it didn't get ground plane coverage. M³ is done the same way. The little silkscreen squares mostly serve as reminders not to run traces from neighboring pads under them and to cover the unsightly holes in the ground plane at the volume control pot.
