P=V^2/R, V=18, R=100, so you made that resistor dissipate over 3 W, which is certainly plenty of warmth. That's well under the resistor's rating, so I wouldn't be worried about burning it up, though in my own dummy loads I put heat sinks on such resistors just to prevent burns to the more delicate nearby humans.
Another application of Ohm's Law is I=V/R, so this resistor caused it to put out 180 mA, well over what you actually need to run the PPA. That makes it a good test.
As for your measurement report, it's a little unclear. What you should be measuring is DC and AC from TP1 to TP3, and DC and AC from TP2 to TP3. This gives four values:
- unregulated DC
- pre-regulator ripple
- regulated DC
- post-regulator ripple
Post the measured values, under load, not subjective impressions, please.
