Originally Posted by tourtelot /img/forum/go_quote.gif
Jeez, all I said was I was confused and frustrated.
Don't be mad, I was just trying to be sure your mind is in the right place for this work. It seems it is.
obviously cross-purpose advice. That is to be expected in a forum setting but it makes for some crazy-making. |
True, but it's also one of the best things about a forum. You could have emailed any one of us directly, and gotten one answer, and been on your way. But is the answer right, and if there are a range of "right" answers, is it the best? How would you know without getting a second opinion? Here, we get to argue and debate our way towards some middle ground answer, which I find is usually more valuable in the end. It's messy, but better than the alternatives.
Tangent: rds is running his PPA as below and it seems to be working fine. Does his set-up bother you on aesthetic grounds for being wasteful or is it gonna blow up? |
My comments above about waste are just me going off on a Tangent. (I do that.) They're nothing to do with your TREAD configuration choices.
To get closer to the ideal of 100% efficiency, you'd have to switch to a class D amp (or similar), which the PPA most certainly is not. So, moot here.
It seemed that the estimator worked backwards, the builder needing a specific final AC output which resulted in a transformer value that couldn't be purchased. |
Propose another way it could work.
A goal-seeker would be ideal, but there's no way it's going to know about the types of transformers and wall warts on the market. There are no standards, and I'm not about to go downloading datasheets for weeks to build up parameter tables for everything available. Even if I did, people would still be upset with it because it wouldn't recommend parts from a distributor in your country, or parts currently in stock, or parts from your favorite distributor or whatever. No matter how you slice it, much of the part selection is up to the person driving the calculator.
Given that, what is there to improve?
Also, to ask for a critical value that can only be measured on an already purchased unit and not spec'd on a data sheet seems a bit of a problem. |
As you've found, power sources from electronics distributors generally do have this info in their datasheets. You don't get it for surplus stock, or wall warts purchased at retail, etc., but that's just the nature of such sources.
Also, most of this problem is just due to your inexperience. You quickly start gaining an intuitive sense for what should work even with incomplete information. The best way to cross that gap is to start building things.
