Alwayswantmore
- Nov 22, 2005
Some background:
If you connect both the mains and the sub directly to your receiver, all three speakers will be driven in parallel. The signal going to the sub will be filtered (at the sub), so only low frequencies are heard from the sub [while the mains are still being driven with the full range of fequencies].
That is why phase shift may be needed to help keep bass from the sub from interacting and canceling bass from the mains [this is what happens in the Bose noise canceling headphones - Bose simply feeds a signal to your ears that is out of phase with the ambient noise, resulting in the noise being cancelled].
As you move to more elaborate (and expensive) systems, some manufactures have a true crossover that feeds only the lows to the sub, and likewise feeds the rest of the signal -- without the lows -- to the main speakers. This method is better because the sub and mains will not fight each other, and the mid-range may improve on the mains because they no longer are being asked to reproduce the low end.
Good listening!
Good listening!
