"If the waveform of the AC power coming in is distorted, that could result in noise making its way to the audio circuitry;"
Surely you jest or have missed the point of several past posts!
I can guarantee you that the waveform of the AC power coming in is distorted by audio standards. Surprisingly, the evidence shows that if you have some kind of power regenerator device, its probably even worse! Every time I've measured it, it was. And if the AC power is distorted on the power cord, jump a few inches of circuitry into the gear, and now it is horrifically distorted.
"Because nothing is perfect, even though the power supplies in most equipment are designed to work under most conditions they're likely to encounter, there is still a huge market for devices that compensate for unusual situations."
IME 99+% of the time, the market in question is based on ignorance and being bullied by salesmen and other audiophiles.
Actually, I don't think I missed any of the "points" - although I'll admit to not finding all of them credible
. I was instead trying to provide a technically accurate assessment of the overall situation (which readers could then apply to the various "points" on their own). Obviously I wasn't entirely successful... so let me summarize what I believe to be the technically relevant points more clearly.
1) Virtually all audio equipment runs internally on DC, and every piece of equipment that does so has a "power supply" that converts the local available AC line current into an appropriate set of DC voltages for that device to run on. That power supply is supposed to be designed such that it can accept whatever comes out of your wall outlet and convert it into DC power that is good enough to run the device properly. (It should not only deliver the appropriate voltages, and sufficient current, but it should also be designed such that it removes any noise likely to be present on "a typical AC outlet" to a sufficient degree that it doesn't affect the device.)
2) This means that, assuming an audio device is well designed, MOST users should not need (or benefit from) external power "conditioning" or regeneration.
2a) If your AC power (wall outlet) is "no worse than average", then you shouldn't need a power conditioner and, if adding one makes your equipment sound better, then it's because the power supply in that equipment is NOT well designed.
2b) Not all equipment is well designed, and some people have AC power that
is noisier than usual, or whose voltage fluctuates more than usual. In those cases, it's quite possible that a line filter or regulator
might help. (However, this is only true for the small percentage of people who actually do have atypical AC power coming from their outlets.)
3) Items 1) and 2) apply almost universally to small signal equipment like preamps, CD players, DACs, etc - which all have regulated power supplies. However, because power amps require large amounts of current, practicality often dictates that they are somewhat less "immune" to line noise and power fluctuations (mainly because, while virtually all small signal devices use regulated power supplies, most power amps do not). In the specific case of power amps, whose output power is usually determined/limited by their operating rail voltages, and whose rail voltages typically are not regulated, it is not uncommon for the maximum output power to be affected slightly by a really bad power waveform. (If the waveform is flattened or clipped, it will deliver a slightly lower peak voltage. This will, in turn, limit the maximum output power some amps can deliver by a few percent. However, in most cases, it won't do anything worse than that.)
I've never personally looked at the waveform delivered by any of the commercial "power regenerators" intended for audio equipment. However, when you talk about devices like "uninterruptible power supplies" that are designed for computer equipment, most of them deliver rather "rough" power waveforms - simply because it requires more effort to deliver a clean sine wave, and most computer equipment is VERY insensitive to the power waveform. (It wouldn't be at all surprising if the waveform put out but a typical computer UPS were bad enough that the power supply in a piece of audio equipment had trouble with it - because they're not intended to be used together. You will typically get much cleaner power from a wall outlet than from a computer UPS. (Many of the uber-expensive power regenerators
specifically sold for audio use
claim to deliver a clean waveform. If they don't, then you're simply wasting money...)
And, to specifically address one question/comment. Standard audio equipment is designed to run on whatever line voltage and frequency is available "locally" - which, for most equipment, is 50 Hz or 60 Hz. Therefore, the power supplies in such equipment are designed to work as designed at that power frequency. Assuming that the power supply is designed properly, there is no reason whatsoever to expect a different power frequency to work better. (And using a power frequency too far from the intended one could cause problems.)
