Originally Posted by philodox /img/forum/go_quote.gif
Any respectable tube amp with a good power supply should be run straight out of the wall. Ask any designer you like. If you plug a tube amp into a power conditioner you will likely just limit dynamics and extension. Unless you want to shell out for an insanely huge balanced torroid and build your own I think this is a really bad idea.
Now for sources and some low power solid state [mainly headphone amps], power conditioning is great.
Multiple steps of power conditioning seems to work for low power gear. On the P300 display it says my Benchmark DAC1 and PS Audio GCC-100 amp take only 10 watts.
That Power Plant Premier is one sexy beast Patrick. You should try taking the P300 out of the equation and just using the Premier with all your components. Who knows, you might be able to sell the P300 and get some cash back for a source upgrade.
I have melted down the plastic for the input and output connectors and hardwired the Valhallas there. There was an improvement when I removed the internal wiring.
I also wonder what impact those other little PS Audio devices have [mwave, ultimate outlet, harvester, etc] now that you are using the Premier.
Harvester didn't make as big difference after I added the Premier.
When I change from Sinewave to MultiWave of the Premier I can hear the improvement instantly. More focus and clarity.
Finally, if the vishnu suck so much why don't you sell them and buy some groceries?
I have cut my Vishnus to pieces and done experiments on them. I offered someone to try them for free and he refused, Vishnu is that bad...I don't know what Nordost was thinking when they designed the cable, they should have listened to it first before releasing it.
Myself I prefer a stock cable over the Vishnu. Vishnu lacks the edginess that makes it sound like real life, it's smoother than real life, it sounds very thin and lean. There are no dynamics.
With Valhalla something weird is happening with the power supply, it doesn't seem like it is neutral. Valhalla sounds both heavy and edgy while being smooth, the heavy speed is not normal! No matter how fat the cable is it gives the illusion of a blacker background and more transparency. With different sizes the detail changes but the transparency still remains. With Vishnu it was dull no matter what size I tried. When I cut Vishnu to pieces I was expecting it to sound close to Valhalla after the mods, I was wrong and had to pay for it.
