Power Cord usages ::
post-148992
Thread Starter
Post #1 of 7
badtz
I was wondering, would installing new power cords [$50-300] into such devices be over-kill? or is that what I SHOULD be doing?
- sound modules
-audio interface
-midi interface
-computer?
and how about.......
-dj mixers [?]
-turntables [?]
-computer monitors
post-150080
Post #3 of 7
fredpb
Overkill.
Maybe if you have money to throw away, you could put some on your audio equipment.
But my particular stance on power cords is...they are snake oil.
But in my case, it's justifying not using any.
post-150297
Post #4 of 7
raymondlin
Architect &Musical Fidelity X-Man v2
Why don't you try make you own? won't cost more then $30 for a cable with the same quailty / parts as a $300 Kimber. I did it, so can anyone. That way, if you can't hear any difference, you haven't lost out much, I bet you can sell it for more on ebay too.
post-150787
Post #5 of 7
badtz
i don't know how to make my own power cords
what applications would the virtual dynamics power cords would be used in [for intance]?
just to connect your sound modules to the outlets?
thanks
post-150815
Post #6 of 7
fredpb
thanks
Don't give premium power cords too much priority. Spend the cash on upgrading components. You should also have a certain level of quality components before you start hearing any difference.
A $200 cord on a $300 receiver, is well............
post-150908
Post #7 of 7
raymondlin
I didn't know how to make a powercord either but I found out that it's no more difficult the wiring a plug, it's THAT simple. The End.
