- Jun 20, 2001
I've been bitten by the upgrade bug again. I'm happy with my Max. I'm very happy with my Sony SCD-C333ES for now. My Tara Labs RSC Reference Gen 2 interconnects are also doing a fine job of getting the music from the 333 to the Max. My Sennheiser HD-600's and MDR-7506's are providing me with fantastic headphonin'. And the Brick Wall I've got is very confidence inspiring as far as surge protection goes. At least as important, the Brick Wall has also lowered the noise floor of my main rig. Overall, the sonic effects of the Brick Wall in the system have been nothing but positive so far -- enough to make me realize that power conditioning can be one of the best bang-for-the-buck upgrades/tweaks
Nevertheless, I'm convinced I can further improve the power delivery to my components, and so I've been weighing my options in this regard. I'm not too far along in my quest for even cleaner power than I've got now, but here are some of the things I'm considering:
It's important to note I haven't used or listened to any of these products yet, but I thought some of you considering power conditioning might find some of my preliminary views of some interest, and might be able to provide additional suggestions/opinions. Again, given price considerations, the two most likely candidates for me at this time are two of PS Audio's 15-amp Ultimate Outlets or B-P-T's BP-3 Balanced Power Isolator. I may get my hands on an Equi=Tech unit and PS Audio PowerPlant too -- we'll see.
For more information, here are some links:
I'd appreciate any comments/suggestions any of you might have regarding power conditioning/balanced power, power regeneration, etc.
As I gain actual experience with any (maybe even all) of the above products, I'll let you know my impressions.
- PS Audio's PowerPlant 300 or 600: Price no object, one of these would likely be my first choice. Advantages include regulation of voltage up and down, they output a good sine wave at all times (which you can play with with the MultiWave settings), and they output balanced power. The only disadvantages I can think of are size, heat (they can run hot), and they consume far more power at idle than any of the other units I'm considering -- oh yeah, and price. These things are expensive (US$1,245.00 and US$2,395.00, respectively), which puts them further down my list than I'd like. Miracles would have to sprout from their very outlets to make me spend that much dough (and maybe they'll do just that).
- PS Audio's Ultimate Outlets: The more I read about balanced power, the more I want balanced power (at the end of this post I'll have some links you should check out to find out more about balanced power). And the Ultimate Outlet, per PS Audio's claims, provides many of the benefits of balanced power (very good differential and common mode noise reduction in particular), but does not produce balanced output -- that is, it still produces 120v/0v output versus a balanced 60v/60v output. What I'm considering is two Ultimate Outlets because there is no isolation between the two receptacles in each Ultimate Outlet, and the power isolation between components is a significant part of what I want to continue to achieve. So advantages include good differential and common mode noise reduction, filtering of the AC, surge protection (which isn't so crucial to me since it's going behind the Brick Wall unti), lowers output impedance of the socket, and can produce as much power as the wall outlet will allow. Another advantage is price if you only need one (US$299.00 for 15-amp version and US$399.00 for 20-amp version). Disadvantages include unbalanced power output, and no isolation between the two outlets in a single unit which means I'd need two Ultimate Outlets to accomplish the isolation I want (US$598.00 for two 15-amp units, US$698.00 for one of each, and US$798.00 for two 20-amp units).
- Equi=Tech Model T1000 Balanced Power System: The founder of Equi=Tech (Martin Glasband) is one of the biggest proponents of balanced power, and, again, the concept of balanced power in audio/video applications makes an awful lot of sense to me (and to many others). The advantages of the Equi=Tech T1000 is the balanced configuration, and all the benefits that come with that: balanced output, strong common mode noise rejection, clean ground due to inversely phased reactive currents cancelling each each other out at the ground, etc. (read the reference links at the end of this message for more details). It also has isolated outlets. The only disadvantage I can see is the price of the unit -- US$989.00, and EMI/RFI filtering is a US$179.00 option.
- B-P-T Model BP-3 Balanced Power Isolator: Now this is the product that I'm looking most seriously at right now. Truth be told -- given the price point I'm looking at and the features I want -- I see B-P-T's BP-3 and PS Audio's 15-amp Ultimate Outlets (plural, because I need two) as the two main contenders for the position in my system between the Brick Wall and my components. I spoke with Chris Hoff (the president/founder of B-P-T) at length yesterday night, and his faith in his products seems genuine. Chris seems to have as much passion for his products and their performance as Paul McGowan (PS Audio) and Martin Glasband (Equi=Tech) do for their their own. And Chris' balanced power products seem to promise all that Equi=Tech's offer, but at significantly lower price points. So far, the reviews I've read of B-P-T products on Audio Asylum have been very positive. I will likely at least try the BP-3 and PS Audio's Ultimate Outlets to see how they compare (I may also get my hands on an Equi=Tech unit). Why am I so interested in the BP-3? Again, all the advantages of balanced power output (see the links below), four stages of EMI/RFI filtering come standard, and two entirely separate balanced transformers (one 1000VA transformer rated at 8+ amps continuous, and one 300VA transformer rated at 2.5 amps continuous) for pretty much total isolation between components (and isolation is a very key consideration for me). B-P-T can also customize their products for specific uses, and Chris found my needs as a headphone hi-fi enthusiast interesting, and even had some suggestions for me on different configurations of a couple of his products that would likely work well for me. I have a few more questions for Chris, but I'm quite close to ordering a BP-3 with some customizations to meet my needs. The retail price of the BP-3 is US$599.00 (the extras I'm ordering would likely add a bit more to the price). The only disadvantage evident to me is that B-P-T's products do not appear to be as pretty to look at as, say, PS Audio's PowerPlants, but this is of little importance to me.
- B-P-T's Balanced Power Isolator products page
- PS Audio's PowerPlant 300 page
- PS Audio's PowerPlant 600 page
- PS Audio's Ultimate Outlet page
- Equi=Tech's home theater and audio power products page
- Equi=Tech's technical papers, articles and reviews page (this is a great informational resource on the topic of balanced power and its benefits)
- B-P-T's "Why Balanced Power?" page
