You guys are talking about two different things.
mofonyx, what you are taliking about is what the equipment will draw from the socket.
Infinitesymphony what you are quoting is the capacity of the device can deliver in theory. The Parasound uses three pairs of 15A transistors. So the maximum capacity is 45A. But the amp can only deliver 200W into 8 ohm load. So the maximum current it can delivered is actually only 5 A without going into large distortion. Notice it also has 40,000 uF of capacitor, that's a lot of reserve current stored. I bet if you turn off the amp, it will play for another 3 to 5 second before it goes off. This is where the peak current comes from.
Usually, there is fuse at the power supply. But many people didn't realize there is also fuse at the output stage to protect the transitors.
What a good power amplifier is actually a good power supply. It can usually withstand lousy power line and peak power demand. IMO, if you have a good power amp, don't worry about power conditioner. And if you have a lousy amp, power conditioner is not going to help you.
