Uncle Erik
Uncle Exotic
- Mar 18, 2006
You can try an isolation transformer - those suppress ground loops and some electrical noise. An "audiophile" model is not necessary. You can find any number meant for electronics hobbyists (to keep from frying yourself) or hospital gear that works fine. Nebraska Surplus has a wide variety of isolation transformers at good prices.
If you are dealing with a RFI problem, that's a little trickier. Shielded cables can lock the noise somewhat, but distance is usually the best cure. If you can relocate your equipment away from each other, that can solve the problem.
