Rdr. Seraphim
- Dec 30, 2008
just go wireless
just go wireless
Every time I go wireless my equipment just goes blank. No blinky lights, tubes don't light up, nuttin'! Good S/N though.![]()
Gotta fight fire with fire. Extremism against extremism. This is the sad part about it.
Seriously though, why would you ever consider replacing your power cord with and aftermarket power cord. I can understand wanting to make one yourself, there's an enjoyment factor there, but buying an incredibly expensive power cord with silver contacts and diamond studded earrings just sounds CRAZY to me. From my understanding, there is no way your power is going to be any "cleaner" by having one of these cables. If you're power is dirty coming from your socket (which is highly likely) then a cable is worthless, invest in a AC/DC converter. Even if your fifty feet away from your socket that can't compare to the hundreds of feet of solid core copper in your walls, not to mention the cables going to your closest transformer. Am I missing something here?
Noise reduction..... better sound follows![]()
Source? After all, it's converted to DC by the amp before it drives the headphones.
Your story is still flawed if he saw you changing the cables, whether you told him it was a "test" or not. The very fact that you changed cables for him after making it clear in the past that you believe in a difference hinted that you expected him to hear a difference, too. So placebo or poor audio memory could have easily taken over and convinced him of an improvement.
Remember you're dealing with AC, so that "last 6 feet" is also the "first 6 ft" of cable too (an extension of your transformer leads).
That means a good quality aftermarket cord is shielded against and can drain off incoming EMI & RF, and it will also prevent radiating it out to other power cords and components in your system!
Want to try something fun?
Get one of these current/voltage detectors that you use to trace wires in your wall (maybe you already have one). Run it past your stock power cords and it will light up & buzz just like the wires in your wall will.
Now pass it along a nice aftermarket power cord, it will be silent. (it is on all the cords I own or have tried)
Story from a long time ago....
I had a friend over listening to music. I excused myself for a moment to swap power cords on the amp (didn't tell him I was testing anything, or "hey, check out the difference...")
After I fired things back up & played the same song again he said to me, "you know, I always thought you were full of s..t telling me power cords made a difference, but the soundstage just went from [..here..] to [.......here.......] when you changed cords."
Personally I feel it's easier to hear things like this in a speaker based system, but it also has merit in a headphone system.
You mention EMI & RF. So, you are worried about noise picked up on cable that transmits AC power? You know it gets regulated later on right?
