Peridot
- Jan 25, 2009
Sorry, I'm a big believer is science, but your post makes no sense. Maybe it's losing something in the translation.
The point of dropping a magnet (not a people) in the tube was to demonstrate that an electrical field is not affected by insulting material. That's all. It's scientifically accurate. His overall point is that unless a wire is shielded, if it's next to other wires that are not shield and they all the electrical current, then the fields around the wires may affect the other wires. This also makes sense.
What he doesn't discuss is how this affects the current, and if there is any negative impact. Peridot even discussed a negative impact of shielding each power wire.
Sorry, if you were trying tomato a point, I completely missed it.
I'd agree with that and I did have to think for a while before grasping the point that castleofarg was tomatoing
I believe it's that in the first video the the passage of the magnet is affected by the presence of the pipe. The shield is impeding its passage.
Therefore it can be deduced that the presence of the shield on the cable will affect or impede the passage of current in the cable, which would be an undesirable effect.
This is indeed another contradiction in the position taken.
Apologies if I've got that totally wrong.
