Power and capability of the Hornet?
Mar 16, 2006 at 11:58 AM Thread Starter Post #1 of 9
milkpowder
Is the Hornet capable of driving a pair of 600ohm headphone like the DT880/600? Has anyone had experience with using high impedance or low sensitivity headphones with the Hornet? How does the Hornet manage battery-life wise?
Mar 16, 2006 at 12:59 PM Post #2 of 9
Old Pa
Definitely yes, I was amazed at the power with my HD580s. I've been using two rechargeable nickel metal 9V I got from Ray with my Hornet and cannot speak to its battery life with disposables. With the NiMe however, I would guess you are in the 30-40 hour range driving the HD580s. Hope this helps.
Mar 16, 2006 at 3:35 PM Post #4 of 9
Elephas
The Hornet drives all my headphones very well. I usually use it with low gain setting.
It's great with the HD650, DT880 (250 ohm) and K701, as well as ATH and Grado RS-1, HF-1.
Mar 16, 2006 at 3:37 PM Post #5 of 9
Jeff E
Low sensitivity: No prob. The Hornet drives the AKG-501s very nicely, even at low gain.
Battery life: No systematic testing but I know that the Hornet's battery (Accupower 270mAh) lasted at least 12 hours driving the 501 with no signs of drain.
Mar 16, 2006 at 5:36 PM Post #6 of 9
raisin
The Hornet will drive any of my phones to levels beyond what any human should listen to, but for the ultimate battery runtime, the SR-71 (w/2 9v's) lasts about 40% longer.
Mar 16, 2006 at 6:23 PM Post #7 of 9
Teerawit
The Hornet drives the Sennheisers just fine.
My friend liked the Hornet + K340 combo too.
Mar 20, 2006 at 12:00 PM Post #8 of 9
milkpowder
Thanks for all your responses.
How does one go about measuring the current output of the Hornet? Do I use the R=V/I formula and hence I=V/R? Does this mean that the lower the impedance of the cans, the more current the Hornet can provide? I heard that the K701 needs a lot of current, can a single 9V give enough current?
Does this mean that the SR71 can put out double the current as well and hence double the volume?
I'm no electronics engineer or physics graduate, so I haven't got much of an idea of this all works. Could someone please enlighten me?
Mar 20, 2006 at 12:16 PM Post #9 of 9
Teerawit
Kinda....doesn't say anything about what current the Hornet can provide though, but rather what kind of current the headphone would like to see. A single 9V CAN give alot of current, at the expense of draining faster.
Not at all. It just means that the SR-71 has more voltage swing. Both amps have different designs so it wouldn't be appropriate to say that the SR-71 can put out double the current just because of higher voltage. In addition, high current doesn't necessarily mean more volume; higher power does. P = I*V = I*I*R = V*V/R.
