Originally Posted by 003 /img/forum/go_quote.gif
I know little to nothing about speakers and proper room acoustics, but isn't having a carpet floor bad for the sound and aren't the speakers supposed to be in the center of the room?
Like OP said, a carpet is actually quite good since it dampens reflections.
Positioning them too close to a wall is on the other hand not so good (if you want neutral representation, that is), since it will raise lower frequencies (by boosting them +3dB with every surface they're in close proximity to, meaning postitioning in a corner would boost lower freq's +9dB).
I can't tell from the picture if the right speaker is the same distance from the wall as the left (as it's cropped), but if not, the left side will project a bit more bass.
The optimal placement would be like 3+ meters out from any reflecting surface in a big and acoustically damped room with no parallell surfaces (meaning a studio control room
You also have to take in account when placing your speakers, that the closer to the wall you place them, the higher up in freq the first cancellation will come. Judging from the picture, I'd guess the first cancellation is somewhere around 70Hz (which I rather have over a cancellation around, say 800Hz).
And a tip to the OP is to put the speakers on spikes (to prevent low freq's from being distributed via the floor). It really does tighten up the bass.
I didn't mean to get all mr lecture-guy on you, but in case somebody was interested, there it is..
