Post your computer specs!~
Nov 8, 2007 at 10:48 AM Post #121 of 3,145
Nov 10, 2007 at 8:48 AM Post #123 of 3,145
Originally Posted by Ethelred /img/forum/go_quote.gif
PSU: http://www.newegg.com/Product/Produc...82E16817703009 $179<- More than enough.
I plan to go SLI in the future.
MEM: http://www.newegg.com/Product/Produc...82E16820146565 $89.99 (49.99 with rebate)
I was already considering whether to use these instead.
CPU Heatsink: http://www.petrastechshop.com/thulhecpucos.html $54 <-Better Perfomance by far, and cheaper.
Thanks for this one. I didn't realize those ones gave better performance. Apparently though, the quality control on this model isn't up to par, and many users recieve them with a warped base.
Case Fans: http://www.petrastechshop.com/12yalod1cafa.html $5 <- Louder, however with a fan controller they are near silent and cheaper.
The CFM to noise ratio on the fans I chose is excellent, which is very important, since I'll be installing so many in this case.
...the 8800GT is performing just under the GTX at half the price.
Heard about this, thanks for reminding me though.
Just a heads up, Nvidia chip sets are known to fail...so if you aren't going to go SLI I wouldn't think it necessary.
Again, I plan to go SLI in the future.(or possibly right off the bat if I go with an 8800GT)
Nov 10, 2007 at 9:22 AM Post #124 of 3,145
Shuttle SD39P2
Intel C2D E6600 @ 2.4ghz @ 1.188v (28C idle)
4GB Corsair DDR2-667
Seagate 400GB 7200.10 HDD
EVGA 8800GTS 320mb
20" Samsung 206BW Widescreen Monitor
Creative T3000 2.1 Speakers (don't use these much anymore)
Logitech MX518 Mouse
Logitech MX3200 Keyboard
Nov 10, 2007 at 8:39 PM Post #125 of 3,145
Their have been some QA problems with the TRUE-120s, however, they have since for the most part been resolved. It came from the mounting system they had, it was far too loose and was causing an improper mount. As for the bases, every base will have some, thus the reason why many people lap them. That's just something that all have, the degree of warpage on the heatsink should be minimal and I have personally never heard of anyone reporting mass warpage in regards to the base.
http://www.xtremesystems.org/forums/...d.php?t=137832 <- Fan reviews
Nov 25, 2007 at 1:16 PM Post #126 of 3,145
Originally Posted by jmmtn4aj /img/forum/go_quote.gif
Processor: Core 2 Quad Q6600 @ 3.6GHz (400MHz x 9) 1.48v vcore + Thermalright Ultra-120 eXtreme (kinda lapped) w/ Scythe S-Flex 120mm
RAM: 2 x 1GB Crucial Ballistix PC2 6400 @ 800MHz 4-4-4-12 (1:1)
Graphics card: Leadtek 8800GTS 640mb @ 650/1000
Motherboard: Gigabyte P35-DS3
PSU: Corsair HX520w
Case: Antec P182
Hard disks: Seagate 7200.10 320GB (primary) + Seagate 7900.9 250GB + Maxtor Plus9 160GB + Western Digital MyBook 500GB Premium ES Edition
Monitor: Viewsonic VX2025wm
I've updated my rig
Core 2 Quad Q6600 @ 3.87GHz (423MHz x 9) 1.51v vcore + Thermalright Ultra-120 eXtreme w/ Scythe S-Flex 120mm
2 x 1GB Crucial Ballistix PC2 6400 @ 1016MHz 5-5-5-15 (5:6)
DFI LANParty UT P35 T2R
Corsair HX520
Lian-Li PC-A70b
Viewsonic VX2025wm
Currently building for my brother:
Core 2 Quad Q6600 + Thermalright Ultima-90 w/ Scythe S-Flex 120mm
4x1GB Crucial Ballistix PC2 6400
8800GT/HD3870 (haven't decided and no stock)
Gigabyte P35-DS3
Corsair HX620
Antec P182
Western Digital Caviar SE16 500GB
LG L226WTQ-BF
The Q6600 in my rig is at 3.6 (450x9) 1.41v though (turns out the previous 1.48 needed was because of vdroop). 3.87 was too warm for my liking. RAMs at 900MHz 4-4-4-12
Nov 30, 2007 at 1:20 AM Post #129 of 3,145
Dfi P965-S
e6400 @ 3.6
2GB HZ's
7900GTO
Audigy ZS
OCZ Powerstream 600 Adju
2 x WD 160GB (Raid0)
1x WD 320GB (backup)
Watercooled in a CM stacker.
Dell 3007 WFP
Logitech G15 / G6
Windows XP Pro
Im waiting for the upcoming 780i board and planning to move to a q6600 and probably 2 8800GT/S (G92).
Dec 5, 2007 at 1:44 PM Post #130 of 3,145
Asus P5K-E Wifi/AP
Intel E6600 (1066)
2GB OCZ DDR2 PC8500 SLI (1066)
Nvidia 8800GTX
Creative XtremeGamer
500GB WD SATA II
Lian-Li PC A05B
Samsung SyncMaster 206BW 20"
Case temp 34C
CPU Temp 30C
Dec 6, 2007 at 2:50 AM Post #132 of 3,145
Well...
"CPUs":
Intel Quad Core Q6600
2x1Gb DDR2 800Mhz
Gigabyte Mobo with P35 chipset
GeForce 8600GT
320Gb SATA2
Sony DVD-RW
CoolerMaster 420w
2x:
Intel E2180 @ 3Ghz
2x1Gb DDR2 800Mhz
ATi Radeon x1950 Pro
320Gb SATA2
DVD-RW
AMD Athlon X2 4800+
2x1Gb DDR2 800Mhz
Mobo nVidia 410 - GeForce 6100 IGP
320Gb SATA2
DVD-RW
AMD Athlon X2 3600+
2x512Mb DDR2 800Mhz
120Gb SATA2
DVD-RW
LCD Monitors:
Acer AL2016W
Acer AL1916W
Speakers:
Logitech X-230
Logitech X-540
Sony MDR-CD180 headphones (I know, I'm here to change it!)
Microsoft Optical Confort 3000 mouse
Benq X120 Keyboard
I think I'm forgetting something...
Dec 7, 2007 at 1:42 AM Post #133 of 3,145
Currently you are running at 3.0GHz (9x333MHz) so you're ram is running at 333MHz (~DDR667). While at the same time you're timings are most likely really low or can be. Or at the very least if you modded them in the bios you could lower them to probably 4-4-4-12 or possibly quicker.
This is what I've found with 5-5-5-15 DDR2-800 memory when run at DDR2-667 speed. To the nearest values (round even), the "correct" timings of 5-5-5-15 rated DDR2-800 memory would be 4-4-4-12 @ DDR2-667.
Dec 7, 2007 at 8:35 AM Post #134 of 3,145
Core 2 Duo E4300 @ 3GHz (Thermalright SI-128 heatsink)
Asus P5B-E Plus
2x1GB TwinMOS DDR2-667
HIS Radeon X1800GTO, flashed to XL and clocked at 594/594 for gaming
Chaintech AV-710
Seagate 200GB
Antec TruePower Trio 430W
Lian Li PC7B+
Viewsonic VX2235wm (22" widescreen)
Cheapass keyboard
Logitech G5
Altec Lansing VS3151 (for surround gaming, youtube videos, low quality streaming music, etc)
Waiting for the next generation of graphics cards so I can upgrade that part of my system (damn you Crysis).
Dec 7, 2007 at 8:38 PM Post #135 of 3,145
Well, its the bare minimum for todays computing standard but here goes:
Ultra X-Connect 500W Power Supply
ASUS A7V333 Rev 2.x
AMD Athlon xp 2100+ 1.7 ghz
XP pro SP2
Thermaltake tornado cpu fan (loud as hell)
1GB PC2300 266mhz total (1x 512mb pc3200, 2x 256 pc2700)
Thermaltake RAM heatsinks
Maxtor 60GB primary
Maxtor 160 GB secondary (dying)
CoolerMaster CoolDrive 4
ATI Radeon 9600 series (yes its AGP)
crappy combo DVD ROM/CD writer
Sony 4x DVD writer
std 1.44 floppy drive (iono why its there... never use it anymore)
3x Blue LED fans
More blue LED case & floor lights
Clear Acrylic Case with Dragon etched side panel
19 inch Sony LCD multi function display (MFM-HT95 or so it says)
Logitech Elite keyboard with its crappy mouse (yes, they're wired)
Sony TMR-IF630R wireless headphones (crap sound, okay for TV
I built this age old computer in 2002, since then it's gone though the video card updates (GeForce 2 > Geforce3 > ATI radeon 9600) as well as RAM (2x 256MB + 1x 512MB) and PSU change (400 > 500w which I think is an overkill, not to mention the fans) and Case switching (aluminium > acrylic in 2004)
Couldn't be bothered taking it out of its case anymore, hey if it ain't broke don't fix it right?
Peace
