Can someone help me on how I can connect the Susvara or TC to turntables?
Post A Photograph Of Your Turntable
- Thread starter Redcarmoose
UntilThen
- Jun 16, 2015
Turntable > Amp > Susvara. That’s how it’s done.
You're going to need a phono preamp unless your table has one built in. Most do not so you would run your turntable into a phono preamp then into your amp (provided it has volume control).Can someone help me on how I can connect the Susvara or TC to turntables?
Cool, so a phono preamp with volume control and a power amp?You're going to need a phono preamp unless your table has one built in. Most do not so you would run your turntable into a phono preamp then into your amp (provided it has volume control).
https://www.amazon.com/dp/B07932QK4...ifi-us-1347492739285757400-20&geniuslink=true
I was actually referring to your headphone amp having a volume control but the phono pre in the link provided will certainly do the job. I'm not sure about the quality of the headphone jack on that though.Cool, so a phono preamp with volume control and a power amp?
Please tell me more about your turntable and phono cartridge as well as the rest of your headphone chain (amp and headphones) so I can make a good recommendation and setup for what you have.
schmalgausen
I listen music since 1973,i was 13 years old,until now,only with turntable and i dont like cd and streaming music.
I have around 10/11 top cartridges now and 3 fantastic turntable after a long research and save money for turntable
I have an idler turntable built in italy,Torqueo T 34 Limited with Saec 506 and the new Kondo IO XP cartridge
The second turntable is another Italian company Vyger with his top of the line Atlantis MK IV,with linear tracking arm on air made with carbon fiber and platter also suspended on air
Here i put a Kondo IOM cartridges
Has a separate big pump at high pressure and a digital box to shere and control the air from the pump to platter and arm
And the third is Techdas AF3 premium with the platter suspended on air with the weight of 29 kg,only the platter,made in different alloy.
I have 3 tonearms
SAT with Lyra Atlas Lambda sl
Triplanar Ultimate SE with Air Tight Opus 1
Graham Elite 12" with VDH Grand Cru
I have 3 tonearms
I always wondered what that one sounds like. It’s a new idler drive turntable, designed from the ground up, isn’t it?I listen music since 1973,i was 13 years old,until now,only with turntable and i dont like cd and streaming music.
Torqueo is an italian company where before improved Garrard and rek o cut.
When they finished to find old rek o cut to rebuild like Schopper and Swissonor do for td 124,they started to build all components and produced a new turntable copying rec o cut but with all much better component.
I had also Swissonor td 124,very good but thi is another level in transparency and dynamic and rhythm
I have a TT2. Haven’t bought the turntable yet. Might get a Dave. I’d like a better audiophile turntable as well. Any thoughts on setting this up?I was actually referring to your headphone amp having a volume control but the phono pre in the link provided will certainly do the job. I'm not sure about the quality of the headphone jack on that though.
What would your budget be? Remember you will need a phono preamp as well if you don't have one integrated into your equipment already.I have a TT2. Haven’t bought the turntable yet. Might get a Dave. I’d like a better audiophile turntable as well. Any thoughts on setting this up?
Not sure. I’d like mid to high end. 5-8k?What would your budget be? Remember you will need a phono preamp as well if you don't have one integrated into your equipment already.
