cmander10
- Sep 8, 2012
Ultimately, a physical chip is going to provide more performance than a program (especially a free one). The sound card will take a small load off your CPU and is going to give you better positioning. You can have your own opinion on the worth of a sound card, but read reviews by actual owners and you will see there is definitely an improvement, so you decide if its worth the cost: money and adding another component into your PC. For me, I think it will be. I am going to get one (Sound Blaster Z), and see how I like it (most likely will).
Really, you will have to try the different brands for yourself as there really is no universal opinion. Also look at the DSP ship since that is your main concern. A $80 model may have the same chip as a $200 model. The $200 model may be focusing more on its DAC or amp.
As far as improving the surround, with no concern on audio quality, get a multi-driver headphone! Really, you can't beat it. I had the HPA-2, and although it wasn't the best sound quality, it was decent enough. Heck I thought it was good before I upgraded to the DT770 Pro. The 770 simply could not match the directional abilities of the HPA-2. No contest: the HPA-2 absolutely slaughtered the 770 in imaging. Muti-driver sets are usually cheap, $80-200 range. The HPA-2 is out of production now, but there are still good choices.
Sorry if it seemed I was derailing the thread. I was mainly telling some audiophiles to knock off with their BS concerning getting a DAC and forgetting the sound card.
One last thing about multi-driver headphones, they have USB power and 4 jacks. You will not need an amp or DAC, simply plug the USB in and then the center, L/R, sub-woofer, and mic into their respective ports.
Cheers
P.S. Also getting a mid-fi setup in a week or two and should be able to give my opinions on that vs the HPA-2.
Cheers
